(讨论)司马台
一个外国朋友发来的邮件
为避免歧意
原文贴注如下
Friends;
Somewhere I recall reading that there are 18 towers of the Simatai section of the wall, and Wang Jing Lou is number 16, so ... (unless the "eighteen" counts one on the west side of the reservoir) there should be two more past Wang Jing Lou ... Ju Xian Lou and one more, past Ju Xian.
In any case, whether sixteen or eighteen towers are in the designated Simatai section of the wall east of the reservoir, I am curious as to what comes next going further east or northeast just AFTER Ju Xian Lou
If I look closely at the attached photo, there are several areas which intrigue me. On the annotated copy of this photo, I have flagged some of those areas, and I am quite curious if you know anything about them.
In the foreground of the photo is Ju Xian Lou; then comes the peak with no tower, whhich I have circled with an "A"
Area "B" in the photo is not very much further east, and it of course very clearly has some sections of the wall on it, and very likely the remaining base only, of a tower. Does that ruined tower have a name?
Area "C" further away has a point which looks like it might be possible wall construction remains "c1" of a possible crumbled down tower.
Circled Area "D" has at its very top, what appears to be a TOWER, at a height which looks much higher even than the Wang Jing Lou! The very distinct straight vertical boundary between sunlit and shaded areas at the high point in that circled area could certainly be a tower. If that IS a tower, it would seem to be quite a majestic setting and a large tower, to be noticeable from the distance here.
Areas "E" and "F" are much closer to the Ju Xian Lou. In those areas the suspicious points are not so clear, but still could be ruins of the wall, especially in area "F."
Can you help me learn what comes after Ju Xian, and what is at areas B, C, and D in this photo? Also, is what I see at areas E and F more remains of the wall?
Is there a digital map you could send me which shows the area from the Ju Xian Tower to the "Area D" on the photo I am sending?
Fei Chang Xie-Xie!!
Tang Sheng Hua again (Walt Thomsen)
本帖由 antelope2006-10-25 23:24:20发表
   (讨论)司马台 【antelope】2006-10-25 23:24:20 [14075] (3K)
     谢谢各位 【sting】2006-11-11 19:17:31 [13230] (73)
     东边我以前去过 【吴桐】2006-10-30 11:40:37 [13426] (273)
       相关的照片请点我的名字,看170-176号精华帖 【吴桐】2006-10-30 11:43:33 [13806] (无内容)
     望京楼东边肯定有楼子了 【驴皮】2006-10-27 21:40:44 [14067] (142)
     在您的B和F处可以确定曾有敌楼 【望京无悔】2006-10-26 02:19:07 [14578] (338)
       这是一位清华大学的长城爱好者给我的照片 【望京无悔】2006-10-26 02:26:12 [14060] (283)
         但那段城墙垮塌严重,边上一座敌楼基座全是文字砖 【半支烟】2006-10-26 23:19:43 [14144] (无内容)
         的确如此 【半支烟】2006-10-26 23:17:15 [13497] (无内容)
     我的翻译很可能不准 【antelope】2006-10-26 00:46:44 [12822] (2K)
       聚仙楼和新城子北沟高楼之间有1个完整的楼和2个残迹 【nothing】2006-10-29 13:52:42 [14581] (24)
         看吴桐的片子,应该有4个 【nothing】2006-10-30 13:25:21 [13176] (无内容)
         这两张照片收藏了! 【望京无悔】2006-10-29 19:21:10 [13475] (无内容)
     照片 【antelope】2006-10-25 23:31:35 [13217] (无内容)
       A、C1、C2、E没有楼子 【nothing】2006-10-29 14:00:55 [13586] (58)
       A点没有任何曾为敌楼的迹象 【望京无悔】2006-10-26 02:28:08 [13121] (无内容)
       老羊辛苦 【火箭人】2006-10-25 23:34:23 [13625] (36)
         别界 【antelope】2006-10-25 23:38:36 [13614] (153)
Time: 0.24829697608948 Sec.
